Stepping down 20v/3.25A into 12v/2A and 5v/1A
Discussion in 'The Projects Forum' started by navdroid, Jul 19, 2013.
  1. navdroid
    Jul 19, 2013
    5
    Hi All,
    Can someone please help in my project? I have a laptop power supply which I would like to use to power a raspberry pi and a LCD screen. The raspberry pi takes 5v/1A and LCD screen controller board takes 12v/2A. I would like to power both using only one power supply, so will need to reduce the voltage down the line before it goes to respective devices.
    I checked switching controllers and voltage converter ICs but my knowledge about these things is very basic. Also, I heard it generates lot of heat.
    Can someone please advice if I can achieve step-down of voltage using good old color coded resistors? if yes, how can I calculate which resistor I need?:confused:
  2. tracecom
    Apr 16, 2010
    3,879
    1,396
    No, you will need voltage regulators. In addition, your power requirements seem too large for the devices. The RP model A needs 300mA or less, and I am doubtful about an LCD that requires 12V at 2A.
  3. navdroid
    Jul 19, 2013
    5
    Thanks for your reply.
    The power requirements are confirmed. The LCD controller board powers up a 15.6" laptop screen and requires min of 2A current. Also, RPi needs min of 750mA current otherwise it starts hanging on applications.
  4. bountyhunter
    Sep 7, 2009
    2,498
    507
    http://www.ebay.com/itm/PM7-HOT-DC-...ravel_Adapters_Converters&hash=item35c9b76af5
    http://www.ebay.com/itm/AC-100V-240...=US_Server_Power_Supplies&hash=item3a7a976151
  5. navdroid
    Jul 19, 2013
    5
    Thanks bounty hunter ut i would like to supply power using one power supply. Two power supply for a tablet wont be practical :)
  6. blueroomelectronics
    Jul 22, 2007
    1,758
    98
    Tablet? Like an iPad? They run on batteries and have touchscreens.
  7. navdroid
    Jul 19, 2013
    5
    I agree but my project is to put a old laptop screen in a photo frame and power it using raspberry pi and use it as a digital photo frame or media device to play songs or other media content.......the device will sit on a desk or may be above a fireplace as a traditional photo frame
  8. navdroid
    Jul 19, 2013
    5
  9. bountyhunter
    Sep 7, 2009
    2,498
    507
    Then why would you care if you plugged one cord or two into the wall?
    There are dual output supplies out there. Here's one for $6
    http://www.coolerstars.com/actodc12duou1.html
  10. absf
    Dec 29, 2010
    1,493
    374
  11. bountyhunter
    Sep 7, 2009
    2,498
    507
    Or, you can buy the one I posted for $6 that's a fully sealed plug in unit that has both converters in it.
