stepper motor
Discussion in 'General Electronics Chat' started by shankar M, Apr 7, 2014.
  1. shankar M
    Mar 27, 2014
    16
    Is stepper motor require 4 inputs to run in forward direction
  2. LDC3
    Apr 27, 2013
    920
    160
    A stepper motor requires the 4 wires to be connected, because you will be setting both forward and reverse voltages on both pairs of wires.
  3. MaxHeadRoom
    Jul 18, 2013
    10,832
    2,502
    Bi-polar or Uni-polar?
    Max.
  4. shankar M
    Mar 27, 2014
    16
    bipolar 1-2 phhase excitation stepper motor
  5. shankar M
    Mar 27, 2014
    16
    im using drv8835 as motor driver ic. for this ic require whether 2 inputs or 4 inputs to run in forward direction
  6. shankar M
    Mar 27, 2014
    16
  7. MaxHeadRoom
    Jul 18, 2013
    10,832
    2,502
    Apart from enable, two inputs needed for direction control.
    Max.
  8. mcgyvr
    Oct 15, 2009
    4,787
    973
  9. shortbus
    Sep 30, 2009
    4,088
    1,670
    The drv8835 is just a H-bridge chip. It by itself won't run a stepper motor. What 'logic' are you using to drive the drv8835? While the drv8835 can drive a stepper, it's more often used for brushed motors, see what Pololu says about it - http://www.pololu.com/product/2135
  10. THE_RB
    Feb 11, 2008
    5,435
    1,305
    It will drive a bipolar stepper motor fine, as it has two independent hbridges inside;
    From what i understand, if it is run in the mode shown above, both enable lines can be left on, and the stepper motor can be driven from 2 control wires; BPHASE and APHASE.
    Like this;
    00 A- B-
    01 A- B+
    11 A+ B+
    10 A+ B-
