MaxHeadRoom
- Joined Jul 18, 2013
- 28,702
Generally in order to do that, you need an initial mechanical design concept.
If using a rack & pinion then you need to chose a rack of a certain pitch and pinion with a diametric pitch together with the estimated weight of moving parts and from there you should get an idea of the effort required to move the load.
You can usually find helpful mechanical design from the sites such as Boston Gear, Martin Sheave, also Misumi who have a huge catalogue which they send out free that also has engineering designs, as well as stocking a very wide range of mechanical components together with online selection guides.
Max.
Max.
