Stepper Motor Substitution
Discussion in 'General Electronics Chat' started by uriahsky, Jan 26, 2013.
  1. uriahsky
    Thread Starter Active Member
    Apr 27, 2009
    42
    I want to find a Cheaper replacement Stepper Motor then what the manufacture wants to sell me. It is being used in a redemption game called Slam A Winner and it drives a platter around in a CC direction all day long. They use the stepper to determine what hole the ball had fallen through. The motor that is in it is a AstroSyn 23LY-C205-03V They want 128.00 for a replacement motor.
    My question is what specs on a stepper motor have to be matched exactly and what specs can just be close?
    I know you have to get the degree correct. This one is a .9 degree and it is a Hybrid that is using only four of the six wires.
    But what about the
    Resistance
    Current
    Inductance
    Torque
    etc...
    The Astrosyn has the following:
    Model Number 23LY-C205
    Voltage 4.0volts
    Current 1.10 amps
    Resistance 3.6ohm
    Holding Torque 3000
    Inductance 5.3mH
    Rotor Inertia 55.0 g-cm2
    Detent Torque 250 g-cm
    Weight 360 grams
    I know what a lot of you are thinking, it depends on the controller? Unfortuantly I think it is a custom controller and I don't have any info on it. It can't be replaced with a generic one, I am pretty sure of that.
    But there has to be some general guidelines I can follow??
    I have searched for answers to this question but could not really find anything. Perhaps I worded the search wrong.
    Anyone help me with this?
    Thanks very much,
    Russ
