Stepper motor Resonance
Discussion in 'General Electronics Chat' started by Gibson486, Oct 9, 2015.
  1. Gibson486
    Jul 20, 2012
    199
    12
    I am a little confused about stepper motor resonance.
    All the stuff I read about says to make the stepping faster to decrease it. However, wouldn't making the stepper much slow also fix the issue? Correct me if I am wrong, but of you go to fast, don't you go faster at the expense of torque? Also, don;t you have to limit the amount of current when you go faster as well so you make sure the coils have enough time to "empty" the current? Also, how do you determine your chopper frequency?
  2. Brainbox
    Member
    Nov 15, 2010
    25
    What are You trying to say?
    Ther are a lot of words but no consistent question.
  3. Papabravo
    Feb 24, 2006
    10,338
    1,850
    The essence of the technique is to move "through" the velocity at which the mechanical resonance occurs. So constant acceleration produces a linear ramp in velocity. If the resonance is at 200 steps/sec, you want to go from 150 steps/sec to 250 steps/sec avoiding the 200 steps/sec range.
    cmartinez likes this.
  4. MrSoftware
    Oct 29, 2013
    542
    132
    You can also microstep to make the stepping much smoother and quieter. Check out your stepper controller to see what microstepping features it has (or doesn't have).
    If you try to accelerate the stepping too quickly, especially if the object you're moving has significant inertia to it, the stepper can get stuck. In this case make some changes to the acceleration profile on your stepper controller.
  5. Papabravo
    Feb 24, 2006
    10,338
    1,850
    The behavior of the rotor with no load is quite different than the behavior with the load attached.
  6. DNA Robotics
    Member
    Jun 13, 2014
    132
    33
    Some people have used a rubber mounted flywheel damper. Also search for a "Rattler". It is a flywheel with captive loose weights in it that rattle when needed to counteract vibrations. They use them on racing engines when a harmonic balancer isn't enough.
