stepper motor question
Discussion in 'General Electronics Chat' started by daredavel, Mar 12, 2010.
  1. daredavel
    Feb 22, 2010
    32
    its my first time using a stepper motor and it has 8pins..can someone help me how to use this? i have provided the pics below..thank you!!
  2. hgmjr
    Jan 28, 2005
    9,030
    214
    Here is your image in a more managable viewing size. Just click on it to enlarge it.
    hgmjr
  3. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    WOW, that's a BIG image! :eek:
    Please remove it, as many of our members are on slow connections.
    I've cropped your image to just the relevant area of interest:
    Does the motor have a part number, and hopefully manufacturer name written/stamped on it somewhere?
  4. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    It's odd that you are reading different resistances between pairs. That might be a challenge to figure out.
    A stepper with 8 wires is kind of handy, because it (normally) can be used as either a bipolar or unipolar motor. The same can be said for unipolar motors (6 wires) as they can be used as bipolar motors once you determine which are the center taps.
    Bipolar motors generally have just four wires. They are most commonly used in industry, as they are more efficient than unipolar motors. However, their drive requirements are much more complex; you need a complete H-bridge for each winding - so for a single bipolar stepper, you need at least two complete H-bridges.
    For a unipolar motor, you simply supply your +V to the center tap(s) of the motor windings, and ground the ends of the motor windings in a sequence to turn the shaft.
    If you can find part numbers on the motor, it will help quite a bit to figure it out.
  5. daredavel
    Feb 22, 2010
    32
    sorry sir! i have removed it.. yup sir! its a..tamagawa stepper motor TS3166N913.. I dont know how to use it sir.. its kinda confusing for me..
  6. daredavel
    Feb 22, 2010
    32
    4.3ohms0.9 deg/step sir..
  7. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    I found this thread:
    http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1241610549
    ...which lead to this thread (Japanese text; translation doesn't seem to help a lot):
    http://members.at.infoseek.co.jp/m_vega/telescope/qcamft/control/control.htm
    At this point, I can only suggest that this motor needs to be operated as a bipolar stepper, pairing up one lower resistance winding with a higher resistance winding properly, as otherwise your steps will be uneven, and the available torque will vary between steps. This may be why the manufacturer has discontinued support for that stepper motor.
  8. russ_hensel
    Distinguished Member
    Jan 11, 2009
    820
    47
  9. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Have a look at this page:
    http://www.cs.uiowa.edu/~jones/step/types.html
    It explains various stepper motor types. Yours appears to be a bifilar. I suspect that there were a number of these motors that were not wound correctly.
    As I suggested before, you will need to pair up a 2.2 Ohm winding with a 5.2 Ohm winding, wired in series.
    The trick here will be figuring out the polarity of the windings, and the correct pair. If you get the pairs mixed up, you will have very poor (if any) performance. If you get the polarity of the windings reversed, you will also get very poor performance.
    You will need two H-bridges to control the motor; one for each pair of windings wired in series.
    If you really don't care about performance, you might try running it as a unipolar stepper; four of the leads going to +V, and alternately grounding the other four leads. However, you will have to limit the current to the lowest common denominator; that of the 2.2 Ohm leads.
    [eta]
    Just found this page (again):
    http://www.luberth.com/cstep/steppers.htm
    Look at the Vexta diagram #5 for bipolar, and #4 for unipolar. That's as good a place to start as any.
