stepper motor interfacing with 8051
Discussion in 'Embedded Systems and Microcontrollers' started by bobparihar, Nov 1, 2014.
  1. bobparihar
    Jul 31, 2014
    93
    iam using 89S52 wit ULN2803A to drive a stepper motor
    iam confused about the connection the stepper motor iam using is shown in the attached picture here
    my code
    #include<reg51.h>
    void delay(unsigned int count)
    int i,j;
    for(i=0;i<count;i++)
    for(j=0;j<1275;j++); // delay about a milli sec
    void main()
    while(1)
    P2=0x01; // uln2803a connected to port 2
    delay(10);
    P2=0x03;
    delay(10);
    P2=0x02;
    delay(10);
    P2=0x06;
    delay(10);
    P2=0x04;
    delay(10);
    P2=0x0C;
    delay(10);
    P2=0x08;
    delay(10);
    P2=0x09;
    delay(10);
    here is the circuit iam following in the attached pics
    problem here is stepper motor do not revolve but when i simulate it in the proteus software with ULN2003A instead of ULN2803A it works fine
    when doing it on hardware when i forcefully try to revolve the stepper motor it resist (vibrate)..
    any one please make me correct
  2. bobparihar
    Jul 31, 2014
    93
    hould i also have to use seprate ground for the stepper motor driving ic(ULN or L293D) and the microcontroller??
    last time when i did make the ground common for both ULN and Microcontroller the axle rotate a single step forward then a single step backward and so on.. back and forth
    but it does not rotates fully clockwise or anticlockwise
