Stepper motor control.
Discussion in 'The Projects Forum' started by sherif, Dec 10, 2009.
  1. sherif
    Oct 17, 2009
    6
    hi all ;
    I want to control a stepper motor by PLC ; can any one tell me how.
    Thnx in advance.
  2. BMorse
    Sep 26, 2009
    2,675
    234
    what type of stepper?? Bipolar, Unipolar??
    Best way to do this is to build a Stepper motor controller board with step and direction inputs, then you can easily control the stepper via PLC by just supplying pulses for how many steps to take in what direction.....
    My .02
  3. mik3
    Feb 4, 2008
    4,846
    63
    First, you need a PLC with transistor outputs.
    Second, you need a stepper motor driver IC which will control the direction of the motor and the pulses applied to the motor.
  4. BMorse
    Sep 26, 2009
    2,675
    234
    Why a PLC with transistor outputs? any TTL level PLC output would work to control a stepper motor controller board / IC.
    You can also use a dual h-bridge to control a Bi-Polar or Unipolar Stepper.
  5. mik3
    Feb 4, 2008
    4,846
    63
    I have never heart about a TTL level PLC. I think you have confused it with a microcontroller.
  6. BMorse
    Sep 26, 2009
    2,675
    234
    Nope, no confusion here, I have worked with a few that accepted 5 volt TTL signals for input/ output....
  7. mik3
    Feb 4, 2008
    4,846
    63
    Ok, but they may have transistor outputs too. The PLC has to be with transistor outputs because relay outputs may not be able to respond to the required drive signal for the motor. Also, switching the relays fast will damage them soon.
  8. Pich
    Mar 11, 2008
    119
    Which PLC are you planning to use? Most PLCs provide a transistor output but most are not fast enough to work with steppers, you would usually buy a special module for the job. Some PLCs have the function built in and provide step and direction at the outputs, a stepper driver is needed to run the motor.
  9. BMorse
    Sep 26, 2009
    2,675
    234
    That is why I suggested to the op to build a stepper motor controller board, and then the PLC just has to supply step pulses and logic for direction....
