STEPPER MOTOR AND WORM GEAR (maths)
Discussion in 'Homework Help' started by isakiwanuka2013, May 12, 2013.
  1. isakiwanuka2013
    May 12, 2013
    Hello
    i need help with a project i am building but need help proving the theory..
    from the ATTACHED image... i have a satelillte (20 kg) mounted on to a flat THIN disk
    the flat metal disk weight is 10 kg
    and it is 50 cm in diameter
    connected at the bottom of this metal disk is a gear connected to it
    which will be driven in a worm gear configuration
    so i wanted to calculate the force needed to rotate the disk 180 degrees in 10 secs
    and also the torque required .
    it will be driven by a stepper motor
    because if i can find the torque i will be able to select appropriate stepper motor and worm gear.....
    this is using more math than anything
    I don't just want the answer i want to know which formulas to use and how to do it
    i want to understand more than anything and learn
    any help would be helpfull
    thank you for your time
  2. shortbus
    Sep 30, 2009
    4,097
    1,695
  3. isakiwanuka2013
    May 12, 2013
    thank you very much
    I am finding the website helpful
    lol I feel embarrased to ask this
    but as i am doing the calculations i was wondering
    is 5Kg the same as 5Kg-m^2
  4. isakiwanuka2013
    May 12, 2013
    or
    I have a thin disk that
    In weight is 30 Kg in total
    It is 0.5 meters in diameter
    So moment of inertia is = I = 0.25xMxR^2
    So I = 0.25x30x0.25^2 = 0.46875 kg-m^2
    is that correct
