Hello!
Is there anyway to make a Stepper Motor Driver using only 555 IC's???
It may be possible for a low-power stepper motor, but it would be ugly and awkward.
It's sort of like "If your only tool is a hammer, everything starts to look more or less like a nail..."
The best use of a 555 with stepper motors would be to provide a clock, at either a variable or fixed rate, for the driver circuit.
That's a better idea!! Thanks I'll try using monostables instead of astables.Interesting configuration. What starts the oscillation? I don't see it. I would have used monostables set up as a shift down setup with one oscillator to trigger the arrangment.
You will have a chaotic situation with all the 555s equal, you need one master, to start the sequenct right.
I've the circuit done. It's not perfect, but works fine (at least while simulating).That's a better idea!! Thanks I'll try using monostables instead of astables.
