stepper driver using drv8825
Discussion in 'The Projects Forum' started by embpic, Feb 20, 2014.
  1. embpic
    May 29, 2013
    187
    i am searching for stepper motor driver schematic using drv8825 controller which is from TI. I am using stepper driver but suffering from noise and need micro-stepping also.
  2. mcgyvr
    Oct 15, 2009
    4,787
    973
  3. shortbus
    Sep 30, 2009
    4,092
    1,672
    Noise and missed steps on a stepper motor is usually from not having a high enough voltage to the motor. The voltage given on the motor data is not the voltage that should be used to drive it. Example a '5V' stepper would use much more than 5V in an application.
