Hi, I'm trying to rotate a bipolar stepper motor (50 oz-in torque) approximately 20 revs per second. Each revolution = 360 degrees. How should this be done? Is it possible to just use 4 steps (90, 180, 270, 360)? Thanks.
We don't have a clue as to what your application is.Would it be better to consider using a PM stepper motor (one with low steps)? Or would that be even worse?
Allright. The load is about .02 lbs. It is a small cylinderical object attached. I want it to stop at 0 degrees and cycle to 360 degrees with large accuracy.
by Duane Benson
by Aaron Carman
by Jake Hertz
by Duane Benson
