Step Model not Show in Altium Designer 14
Discussion in 'Embedded Systems and Microcontrollers' started by Rizky, Feb 15, 2015.
  1. Rizky
    Jun 27, 2014
    when I enter the 3D Step Model to my pcb library, the model does not appear....
    i have go to Place > 3D Body, i'm choice Generic Step Model, then i'm hit Ambed Step Model, and i have chose my Step File, but when i'm click OK Button, the Model isn't Appear / Show in my PCB doc/ Library.....
    Can Someone help me, What Should i do?
  2. spinnaker
    Oct 29, 2009
    5,102
    1,190
    I suggest you see if there is a forum on the Altium site. The changes of someone using that product are pretty slim. Or contact their tech support. If you have a licensed copy then getting help from tech support should not be an issue.
  3. Rizky
    Jun 27, 2014
    I had try (trial and error) to solve it and succeed. my fault lies in input "Standoff height" = 0 mm (3D Body Window). Then, i'm trying to change it to 1 mm. the result, my model show into my PCB.
