step input to underdamped system
Discussion in 'Homework Help' started by vvkannan, Jan 15, 2009.
  1. vvkannan
    Thread Starter Active Member
    Aug 9, 2008
    138
    11
    Hello ,
    This is another problem in which i dont know how to proceed.
    When a unit step input is applied , a second order underdamped system has a peak overshoot of OP occuring at tmax.If another step input equal in magnitude to the peak overshoot OP is applied at t = tmax then the system will settledown at
    a)1 + OP
    b)1 -OP
    c)OP
    d)1.0
    thank you
