step down transformer
Discussion in 'General Electronics Chat' started by jgsmuz, Jun 8, 2008.
  1. jgsmuz
    Jun 8, 2008
    I have a question for anyone out there. I am trying to make a step down transformer work. It is 480 primary and 240 secondary. I cannot figure out how to wire it. The label is confusing and I have never done this before. Anyone?
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Have you got a meter? The primary will probably have a few more ohms resistance than the secondary. How many leads are there?
  3. mrmeval
    Distinguished Member
    Jun 30, 2006
    833
    Do you have a picture of the connections? And labels? Model number? etc
  4. alim
    Dec 27, 2005
    113
    Hi is this a double wound transformer? Two separate windings? If it is identify each coil, apply 240 volts to either winding if you get 480volts on the other winding , you would have identified the respective windings if you get 120volts instead the windingss are reversed.
