Step Down Transformer (Foysal1271)
Discussion in 'The Projects Forum' started by Foysal1271, Feb 22, 2016.
  1. Foysal1271
    Feb 22, 2016
    Hay guys I need yours help. I want built a step dawon 12-0-12, 10 amps transformer. But problem is I don't know the formula. So any buddy can be help me
  2. MaxHeadRoom
    Jul 18, 2013
    10,827
    2,495
    The whole transformer from scratch or modify one?
    Max.
    Foysal1271 likes this.
  3. bertus
    Administrator
    Apr 5, 2008
    15,796
    2,384
  4. Foysal1271
    Feb 22, 2016
    Sir.
    I can't get yet any solution pls help me
  5. tcmtech
    Nov 4, 2013
    2,106
    1,747
    The simplest way would be to get an already made off the shelf unit from an old 12 volt automotive battery charger.
    The vast majority of them are designed around a simple 12 - 0 - 12 secondary winding.
  6. MaxHeadRoom
    Jul 18, 2013
    10,827
    2,495
    For modifying your best bet is a Toroidal of the required Va, they are very simple to wind a secondary on if you have one with one with a primary suitable for your local power.
    You can find the Turns/v from a secondary already present.
    Max.
  7. #12
    Nov 30, 2010
    16,660
    7,305
    This job is a gigantic PIB. You have to start with the qualities of the core material, figure how many pounds of core you need for the watts, the number of turns in the primary for your local voltage, allowing for the power line to be +/- 5%, then the secondary turns allowing for efficiency losses in the core, and wire gauge. It takes a lot more than one formula to do all this. Do you even know where to buy the core? I don't.
    Either get a transformer made for this job or at least get a core that has the right primary on it.
