Step down transformer circuit
Discussion in 'The Projects Forum' started by Mcklein.tunde, Apr 23, 2016.
  1. Mcklein.tunde
    Apr 23, 2016
    Please how can I wire a step down transformer to give an output of 110v and 6w? I actually have a step-down of this specification but output power is 200watts. Can this power be altered?
  2. Alec_t
    Sep 17, 2013
    5,956
    1,132
    Welcome to AAC!
    If you have a transfomer with a 110V output rated at 200W then it will be quite happy driving a 110V 6W load. The load determines the power demand.
  3. Mcklein.tunde
    Apr 23, 2016
    Just wondering...... Looks like the output power is too much for the load.
  4. Alec_t
    Sep 17, 2013
    5,956
    1,132
    No. 200W is the rated maximum that the supply can safely provide.
    Think about your house mains supply. It is rated to supply many kilowatts of power, e.g. for water heaters, fires, air-conditioners. When you switch on a 10W lamp, does it use all those kilowatts of power? No; it uses only 10W.
