Step down converter
Discussion in 'General Electronics Chat' started by SAIFULLA1, Jun 25, 2012.
  1. SAIFULLA1
    Jun 25, 2012
    I have a hair dryer which is of japan it needs 120volt where as i have a 220volt switch board in india its 220volt current supply so can anybody help me to built a transformer of step down converter
  2. t_n_k
    Mar 6, 2009
    5,448
    783
    Are you sure there isn't a voltage selector switch somewhere on the hair dryer? If it's a hand held type they often come with that option built in.
    Otherwise it's probably just as cost effective to buy a hair dryer compatible with your current 220V supply voltage.
  3. Wendy
    Mar 24, 2008
    20,772
    2,540
    I don't think this qualifies as a physics problem, so I have moved the thread here.
  4. crutschow
    Mar 14, 2008
    13,471
    3,359
    "Travel" step down plug-in transformers to perform that function are very common.
  5. mcgyvr
    Oct 15, 2009
    4,784
    973
    Lets see...
    step down transformer for a hair dryer.. $40 USD???
    New hair dryer=maybe $20 USD??
    Solution is simple..
  6. SAIFULLA1
    Jun 25, 2012
    I actually needed to built a step down transformer. That's if the voltage is 220 volt i needed it to 110volt if its 110volt i need to 2volts. That 220volt to 2volt range i only need a some circuit diagrams to built it and few steps and some info and the list of components needed to setup a step down converter/transformer. In india we have 220 voltage supply so i need not need a step up converter/transformer. I only need is only a step down converter/transformer. Can some help me in making this device(step down converter/transformer)
  7. mcgyvr
    Oct 15, 2009
    4,784
    973
    No you don't.. you need to buy a new hair dryer.
    2 volt???
