step down converter
Discussion in 'General Electronics Chat' started by nandax, Mar 17, 2009.
  1. nandax
    Nov 20, 2008
    12
    I'd like to use MC34063A as step down converter from 9 V to 3V
    my question is , how can I determine the output current? is there a formula for that? can somebody tell me
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    The load that is fed by the 3 volt supply will determine the current. If it is resistive, then Ohm's law works - I = E/R. Current equals the voltage divided by the resistance.
    If the load is active, the spec sheet for that device should give you the information.
