When I was starting in the 70's I would take the schematic (usually hand drawn), draw the parts upside down (since that is how a board is laid out), and hand draw the PCB.
I assume you are talking only about through-hole construction with leaded components. If the labels were printed on the solder side, but not the component side, wouldn't you have to turn the board over even more often to find out where to insert each part? Why do you want to know what the component is as you solder it?They ought to print the "R1" "C2" etc. values info on the solder side so you could just poke the components through the bottom and zip right through it in stead of flipping the board over a "pico" amount of times!
by Jake Hertz
by Duane Benson
by Jake Hertz
by Jake Hertz
