Steadying motor speed
Discussion in 'General Electronics Chat' started by Veracohr, Apr 6, 2011.
  1. Veracohr
    Jan 3, 2011
    559
    77
    I've got a belt-drive turntable which has very slight but regular speed (and thus pitch) fluctuations and was wondering if there's a way to really lock down the motor speed. I checked the voltage the motor is getting and it's pretty darn steady; my scope showed it fluctuating no more than 0.1Hz around 60Hz. Any ideas? Or is this just something you have to deal with when you have a cheap belt-drive turntable?
  2. debe
    Sep 21, 2010
    955
    185
    How old is the belt? do the motor bearings need lube. Asuming this is not new.
  3. John P
    Oct 14, 2008
    1,639
    225
    What is the period of the variation in speed, is it once per motor rev or once per table rev? If it matches the motor, I'd check to see if the drive pulley is off-center. If it's once per table rev, likewise for the pulley that drives the table (or the entire table, if the belt goes around the table edge). If it's neither of those, then maybe it's the speed of the motor.
  4. Veracohr
    Jan 3, 2011
    559
    77
    I think it might be about the period of the table revolution. I'll check when I get home. It's definitely a slow period.
    It's not old, maybe 3 years or so, but IIRC it's done this since it was new, so I kind of doubt the motor needs cleaning or anything like that.
  5. THE_RB
    Feb 11, 2008
    5,435
    1,305
    Thye should have a new belt every couple of years.
    Belts are still commonly available through HiFi shops and repair centres.
  6. debe
    Sep 21, 2010
    955
    185
    If its one rev of turntable it will be the belt, it will have afaulty patch in it were it has stood for a long time around the motor shaft, seen this fault before. Replace the belt they arent expensive.
  7. Kermit2
    Feb 5, 2010
    3,854
    968
    Second on the belt diagnosis.
    Sitting unused they 'form' into the shape of the pulleys. They also get brittle and cracked with long exposure to atmosphere oxygen and loose gripping power.
    Change the belt.
  8. Veracohr
    Jan 3, 2011
    559
    77
    OK, I guess I'll try to find a replacement belt, but as I said it's only a couple years old and I'm pretty sure it did this when it was new.
  9. John P
    Oct 14, 2008
    1,639
    225
    It can't possibly be the belt. If it were, the variation would occur once per pass of the belt, not once per revolution of either pulley. Most likely a bulge or kink in the belt would show up most when it goes over the motor pulley, as that's smaller. Spread out over a large circumference, as the output pulley would be, I doubt if you'd notice it.
  10. eblc1388
    Nov 28, 2008
    1,542
    102
    Remove the belt and manually turn the turntable platter slowly. Feel with the hand the applied torque/reaction to see if at any position there is a "click" or change in " mechanical resistance".
    If the platter turns very smoothly, then it will be the belt.
  11. debe
    Sep 21, 2010
    955
    185
    In one rev of the turntable a faulty spot on the belt will pass the motor pulley.
  12. John P
    Oct 14, 2008
    1,639
    225
    In one rev of the turntable a faulty spot on the belt will pass the motor pulley once at most, and possibly not at all.
  13. John P
    Oct 14, 2008
    1,639
    225
    Good idea about checking the bearings for smoothness. But there is the possibility that even if the bearings work correctly, the entire pulley is off-center. A pulley that's not perfectly circular would have a similar effect.
  14. THE_RB
    Feb 11, 2008
    5,435
    1,305
    It's the most typical symptom of belt failure; repeating pitch fluctuation.
    Generally the belt circumference is only 10 or 20% larger than the turntable pulley circumference so to the user the pitch fluctuation appears very similar to turntable speed.
