im having trouble trying to figure out where the 1 is coming from? all i can think of is the forward gain (G) is receiving the feedback factor as a voltage and sending out the error signal as a voltage so it will be dimensionless so the 1 will be a constant. But when you have your value for loop gain it says you add a 1 to it for example 1 + GH, then for closed loop gain it will be G/(1+GH). i just cant understand where the 1 is coming from and why were using it
