Steady-state analysis: PSpice Capture modulation
Discussion in 'Homework Help' started by Moskits8, May 5, 2015.
Why does Pspice says that nodes are floating? how to fix this problem with this schematic?
  1. what to do!
    0 vote(s)
    0.0%
  2. ac sweep
    0 vote(s)
    0.0%
Multiple votes are allowed.
  1. Moskits8
    May 5, 2015
    7
  2. Jony130
    Feb 17, 2009
    3,991
    1,116
    In DC steady-state analysis PSpice treats all capacitors as a open circuit and inductors as a short circuit. And this is why the nodal voltage is floating.
    Moskits8 likes this.
  3. Moskits8
    May 5, 2015
    7
    How to resolve this problem so I could simulate AC sweep with no errors !
  4. Jony130
    Feb 17, 2009
    3,991
    1,116
    Add 1G resistor parallel with capacitors.
  5. kubeek
    Sep 20, 2005
    4,689
    806
    Or skip DC point calculation.
    Also, why the hell is this a poll?
  6. Moskits8
    May 5, 2015
    7
    Skipping does not help! :(
  7. Moskits8
    May 5, 2015
    7
    There is no errors , but ""print parts"" shows that voltages and currents are zeroes!
  8. Jony130
    Feb 17, 2009
    3,991
    1,116
    Are you preforming AC sweep analysis ??
  9. Moskits8
    May 5, 2015
    7
    AC sweep analysis linear at 1 point in start&end 50 Khz!
  10. Jony130
    Feb 17, 2009
    3,991
    1,116
    Change into Octave and 110 points per octave.
  11. Moskits8
    May 5, 2015
    7
    Thanks for help!
    If i can ask one more question ?
    Im makilng parallel L circuit with coupling !
    And there is this error!
    ERROR Schematics 05:33PM Attribute Part K_Linear has no "L1" attribute
  12. Jony130
    Feb 17, 2009
    3,991
    1,116
    Try show as the circuit diagram.
  13. Moskits8
    May 5, 2015
    7
    Fixed myself! Thx Jony130 for help!
