Hi folks,
I have a couple of air doors to generate wind over a thermal collector test, but the speed controls that came with them are low rent and at the low speeds I need they seem to hunt around speed wise.
What is a good strategy to get steady slow variable speed control?
We mostly do NOT need the higher speeds.
The control on them is from KB Electronics (HK) Ltd.
Model KBWC-16
6.0A FLA
14.5A LRA
120VAC
Motor is 1/5HP draws 3.4A at 120V
Can I upgrade the KB?
Is there a higher quality fan dimmer to buy - that is any better?
Can I build something?
Thanks,
Mike
Model KBWC-16
6.0A FLA
14.5A LRA
120VAC
Thanks,
Mike
