state-variable and biquad filters
Discussion in 'Homework Help' started by PG1995, Jun 2, 2012.
  1. PG1995
    Thread Starter Active Member
    Apr 15, 2011
    753
    5
  2. mlog
    Member
    Feb 11, 2012
    276
    36
    It's called a biquad filter because it is developed from a biquadratic equation of the form ax^{4}+bx^{2}+c=0.
    PG1995 likes this.
  3. PG1995
    Apr 15, 2011
    753
    5
    Thank you, mlog.
    Could someone please help me with the Q1?
    Regards
    PG
  4. Jony130
    Feb 17, 2009
    3,993
    1,116
    As for Q1 figure 15-12 show the answer to your question
  5. PG1995
    Apr 15, 2011
    753
    5
    Hi Jony
    I think you referred to FIGURE 15-21. Please have a look on the attachment. Thanks.
    Regards
    PG
  6. Jony130
    Feb 17, 2009
    3,993
    1,116
    OK I see why you get confuse.
    We set each integrators to have Fc = Fo = 7.23KHz and this Fc is -3dB for LPF and for HPF. But not for BH filter. The maximum output in BH output we get at frequency equals to Fc = 7.23KHz. So for the BH output this voltage is our 0dB not -3dB.
    This imagine show everything
      File size:
      75.5 KB
      36
    PG1995 likes this.
  7. steveb
    Jul 3, 2008
    2,433
    469
    For Q1, the answer is that you can't just think blindly about parameter definitions. The idea of "bandwidth" is a concept that is defined relative to the total response, or final output. You need to define new 3dB points in the final output response, then the numerical value of the bandwidth will be clear.
    Think about it, what if you shifted the highpass filter cutoff above the lowpass filter cutoff? Would you then have negative bandwidth? No, the response would still have a peak, and there would be points on either side of the peak that are 3 dB down from the peak. It's all relative.
    PG1995 likes this.
