State Space Mohann
Discussion in 'General Electronics Chat' started by gusmas, Apr 8, 2013.
  1. gusmas
    Thread Starter Active Member
    Sep 27, 2008
    239
    Hi
    I am currently working through Power Electronics, Converters, Applications and design by Mohan. Now I am at chapter 10, where a avg state space model is derived for a dc-dc converter. Problem I am having is how he derives the state variables.
    I understand how he got eq `10-63, using KVL, however I can not understand how he derived 10-64. It seems like he is using KVL again but only in the RC part of the converter??
    I have a image of the page I am referring to. See attached
  2. t_n_k
    Mar 6, 2009
    5,448
    783
    The second equation is indeed obtained by the application of KVL around the right hand side loop - having regard to the currents flowing in each branch.
    If you require further elaboration, I'm sure some help will be forthcoming - alternatively you might consider carefully annotating the circuit and resolving the matter yourself.
    Perhaps I should at least offer a hint.
    The current in the capacitor [C] + resistor [rc] branch will be related to the capacitor voltage x2 such that
    i_c=C\frac{dV_c}{dt}=C\frac{dx_2}{dt}=C\dot{x_2}
    The current in the load branch resistor [R] will then be given by
    i_R=x_1-i_c=x_1-C\dot{x_2}
  3. gusmas
    Sep 27, 2008
    239
    HI
    I understand the maths on how they did it, I just always thought if you use KVL with the one state space variable, you have to use KCL to solve the other.. haha very stupid mistake :D.
  4. gusmas
    Sep 27, 2008
    239
    ME AGIAN :D
    I am on the next page and got stuck again.. sigh I know..
    Its how he calculates Vo...
    _{}V_o = R(x_{1}-C \dot{x_{2}})
    I have no idea what happens after that line (eq 10-70)
    I can understand he is taking x1 (Indcutor current) and multiplying it with the total resistance to get the output voltage, but why is he adding the (R/(R+ rc)*x2?? Is that the voltage potential that is already inside the cap, and he is just calculating the voltage potential at the resistor using ohms law??
  5. t_n_k
    Mar 6, 2009
    5,448
    783
    It follows from ....
    x_1=\(\frac{v_o-x_2}{r_c}\)+\frac{v_o}{R}
    hence
    v_o\[ \frac{1}{r_c} + \frac{1}{R}\]=x_1+\(\frac{x_2}{r_c}\)
    etc....
  6. gusmas
    Sep 27, 2008
    239
    Please bear with my stupidity....
    The state variables are the following:
     x_1 = Inductor current
     x_2 = Capacitor Voltage
    If I take equation 10-70, and make X1 the subject of the formula I get the following:
    x_1=C*\dot{x_2}{}+\frac{v_o}{R}
    Now because the current inside the capacitor equates to the following:
    C*\dot{x_2}
    additionally: the current through the capacitor will be same as the current through the series resistance presented by the cap (rc).
    C*\dot{x_2} = I_r_c
    thus
    I_r_c= \frac{v_r_c}{r_c}
    thus the voltage over rc is:
     v_r_c = v_o - x_2
    finally, by using ohms law the current through rc AND the capacitor is:
    I_r_c = \frac{v_o - x_2}{r_c}
    is this correct? It makes sens to me.
  7. t_n_k
    Mar 6, 2009
    5,448
    783
    Your reasoning seems a bit convoluted but the outcome is correct.
    I viewed the situation as follows....
    The current from the inductor [x1] divides between the R branch and the rc+C branch.
    The current in R branch is just Vo/R
    The current in rc+C branch is [by simple deduction] (Vo-Vcap)/rc
    Since Vcap=x2 then the current in rc is (Vo-x2)/rc
    So x1=Vo/R + (Vo-x2)/rc
    etc....
    gusmas likes this.
  8. gusmas
    Sep 27, 2008
    239
    Ye lol I am not good with explaining things, but my way of doing it was the same as yours!! thanks a million for the help :)!!!
