State Macine on PIC
Discussion in 'Programmer's Corner' started by mlkcampion, Jan 19, 2007.
  1. mlkcampion
    Thread Starter Active Member
    Nov 16, 2006
    59
    Hey Forum
    anyone know of a good website that explains how to implement
    a state machine. I just need a few notes on there general structure
    and how best to acheive a stable and flexible program.
  2. hgmjr
    Jan 28, 2005
    9,030
    214
    Greetings mlkcampion,
    I had a surprisingly difficult time googling a document that addressed the basic state-machine technique. I located this link to a document that seems to present the technique in a way that should be easily understood.
    You didn't mention your programming-language of choice so I chose to look for a C-language example in hopes that you have a familiarity with C. Most though not all C-languge implementations use the "switch" construct as the basis for the state-machine. Usually a state-machine begins with generating a state-diagram or state-table.
    I have found state-machine coding to be both straightforward to write and generally fairly easy to debug.
    I hope this information helps advance your understanding of the technique.
    hgmjr
  3. n9352527
    Oct 14, 2005
    1,198
    Another article.
    When you have had a read and still have questions, post the specifics and we could go forward from there.
