I forgot the link http://forum.allaboutcircuits.com/showthread.php?t=44852Where, i can't find??
Last line of quoted message: "20. delay exceeds maximum limit of 197120 cycles"HI,
while building project it show error...why?
step i have done...
1. create new project PIc16F877A next
2.save a file with testpic next
4.next ( I have not add any file)next
5.finish
6.open new file paste my code
7.save code by testpic.c
8. then right click i add to project
9.after that i build it show this error, why??
This has been fixed in later versions of the HI-Tech C compiler also. If the OP use version 9.83. As he said in post #4 (I think). It will not be a problem. However your point is quite good. Then the compiler give an error. Read the error message. If still in doubt look the error up in the manual. Learn to know the manual, and it will be your best friendLast line of quoted message: "20. delay exceeds maximum limit of 197120 cycles"
This means in line 20 the number passed to the delay routine is too large. Either call it several times with a smaller number or use another delay routine.
Dude You gave a link showing which C-compiler you used in post 6. And strangely enough you will also find downloading links on this page. That is for 9.83 Thats why assumed you used this version. The download is free for the compiler in LITE mode. So just download and have fun. Then you have installed remove the older version.Hi,
In my C drive there is only PIC->PRO->9.65 no other now what to do??
I am on slow connection so can't download can't we use this version??The download is free for the compiler in LITE mode. So just download and have fun. Then you have installed remove the older version
Slow line fair enough. Try to reduce the delay time to 100msec. Then run it 10 times in a for loop http://cprogramminglanguage.net/c-for-loop-statement.aspxI am on slow connection so can't download can't we use this version??
Yesterday i have tried that also but it was not working...Try to reduce the delay time to 100msec.
LOL I think you downloaded the MAC\OSX version. Download the windows version and you should find a exe fileI have downloaded this picc-9.83-osx for my window 7 64bits tell me what to do as there is no set up found in it?
In the link you posted in post #6 One is marked OSX, one is marked linux. What do you think. Will either of these work on Windows OS. I guess no. So once more. If you have downloaded any thing else than the file "picc_9_.83_win.exe" You have done something wrong.I think it is for window if not then which r u talking...?
anyway, i have downloaded this ...8.87 is there any need of any other thing now??
Then you need to install the compiler silly!NOt yet, i have installed map lab 8.87 i don't find Hi tech C in it..
OK, I have installed it, and the project is build ..And now you have for sure downloaded and installed the 9.83 version of the Hi-Tech C compiler. Yes or no.
