Starting light system
Discussion in 'The Projects Forum' started by dfarley, Mar 10, 2014.
  1. dfarley
    Mar 10, 2014
    I would like to build a starting light similar to the one used in Global Rallycross.
    The light sequence can be seen here http://youtu.be/Wi25M8qc2EU
    There are 5 red lights that turn on in a sequence then all go off. After 3-5 seconds the green lights all turn on starting the race.
    I would like to drive trailer/reverse lights as the output and was thinking of using a decade counter. Perhaps a circuit like this could work http://www.allaboutcircuits.com/vol_6/chpt_7/6.html ?
    I am unsure how to get a random 3-5 seconds after the red lights turn off.
    Thanks!
    Dan
  2. Bernard
    Aug 7, 2008
    4,240
    414
    In the find box, upper right of this page, put in HubertH, and go down to pseudo time delay. Look it over and see if any part fits your need. We can modify & combine to fit your need. & as usual, Hubert did not give us a final report.
  3. inwo
    Nov 7, 2013
    2,435
    315
  4. Bernard
    Aug 7, 2008
    4,240
    414
    It's all down in pencil & papper, just need to ink it in & find out how long the green
    lights stay on, as of now they are set for 5 sec.
    Looks like 5, 555's; 2 4022's [ or 4017 with pins changed ]; 1 4071 OR; 1 invertor; & drivers, MOSFETS or transistors.
  5. Bernard
    Aug 7, 2008
    4,240
    414
    Once started might as well finish even tho it appears that OP has flown the coop.
