Starting an ATX power supply with piezo sw
Discussion in 'General Electronics Chat' started by spondootre, Sep 21, 2006.
  1. spondootre
    Sep 21, 2006
    8
    I'm working on a small project which is nearly completed, I have 100 white LEDs and 100 colour change LEDs wired to a modified ATX power supply. I was going to switch this supply on using a normal throw switch to connect the pwon/pwgrnd (green/grey) wires but I have found a switch that I would like to use instead on the RS website here :
    www.rswww.com
    then enter :
    665-641
    as the part number to search for.
    It is a piezo actuated pushbutton switch which is momentary. Does anyone have a simple circuit I can use with this switch to turn the PSU on and off ?
    regards
    Malc
  2. spondootre
    Sep 21, 2006
    8
    OK i've now maybe decided to scrap that idea but am wondering about using this :
    http://documents.rs-components.com/...DOCBASE=techlib&DMW_OBJECTID=0900766b801e5ba7
    how can I wire the PSU to use this switch? The powersupply starting voltage is 5v when connected to any ground wire it starts up. Would I connect the +5vPSU to + on the switch, and the same wire to OUT on the switch then groundPSU to 0v on the switch ?? I can't get my head around it.......
  3. spondootre
    Sep 21, 2006
    8
    I'm wondering if there is a timer circuit that I can use with these switches, if I use the pulse capacitor switch could I use this with a timer that switches the PSU on for say 10 mins? Can anyone come up with a citcuit I can use for this?
    any help is greatly appreciated.
  4. spondootre
    Sep 21, 2006
    8
    Would this be correct?? Capacitive sw added to the left of the cct.
