Starting a 4017 from an output other than 0
Discussion in 'The Projects Forum' started by Otaku, Mar 24, 2010.
  1. Otaku
    Thread Starter Active Member
    Nov 19, 2008
    128
    Hi all,
    I'm working on a LED sequencer and am wondering if a 4017 can be "told" to start on an output other than "0". I want to sequence 3 LEDs from outputs 0-2, using O3 as the master reset. No problem there, but I also want to be able to sequence 3 LEDs from outputs 4-6, using O7 as the MR. There would have to be two separate triggering conditions, I think. If this can't be done, I can just use two 4017s for this project. Thanks for all advice.
    Gary
  2. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Nope. Go fish!
    You might consider using a universal shift register that has the parallel inputs pre-set. Have the 4th and 8th parallel outputs trigger the parallel load input.
    [eta]
    Since you can't wire two outputs together, you could use a pair of 1N4148/1N914 diodes and a pull-down resistor to create an OR gate.
  3. R!f@@
    Apr 2, 2009
    8,785
    771
    LMAOF :D
    Good one.
  4. Otaku
    Nov 19, 2008
    128
    Yep, that's what I was afraid of - thanks!
