Start transistor when voltage is correct
Discussion in 'General Electronics Chat' started by FroceMaster, Oct 18, 2016.
  1. FroceMaster
    Jan 28, 2012
    402
    Hi
    Need to do a circuit that will set volt to a transistor when the supply is more than 13v and shut off again when under 13v
    Can this be done simpel ?
  2. dl324
    Distinguished Member
    Mar 30, 2015
    3,377
    651
    Probably. What are the design constraints and voltages are available?
  3. wayneh
    Sep 9, 2010
    12,379
    3,232
    Define simple. If I understand your needs correctly, I would use a comparator with a small amount of hysteresis. There are other options also. If you already know what that means, it will be simple.
  4. #12
    Nov 30, 2010
    16,670
    7,314
    My dental appointment got cancelled today, so I'm bored enough to do useless stuff like answer the question as it was asked instead of playing 20 questions with the T.S.
    absf likes this.
  5. wayneh
    Sep 9, 2010
    12,379
    3,232
    You just convinced me to put the laptop down and go outside. Sunny and warm here, which is rare for the season.
    #12 likes this.
  6. FroceMaster
    Jan 28, 2012
    402
    HAve now drawn a little sketch,
    When voltages goes over 13v the transistor should open fully and "pull" the load.
    When voltages is below 13v the transistor should completly close.
      File size:
      79.7 KB
      18
  7. wayneh
    Sep 9, 2010
    12,379
    3,232
    Is the voltage supplying the load the same as the one you want to control the switch, or are they independent?
    You may be able to use a simple resistive voltage divider to bias the transistor.
  8. FroceMaster
    Jan 28, 2012
    402
    Source is the same but need to control the load with max 10mA and the load is 10A by a relay. So the transistor only need to draw 100 mA
  9. wayneh
    Sep 9, 2010
    12,379
    3,232
    I believe a TL431 voltage monitor circuit would work for you. Here's one example using an LED, which you would replace with your relay coil.
  10. FroceMaster
    Jan 28, 2012
    402
    Sounds a little difficult . All that calculate to find out resistor and will it be able to draw the relay ? Can i drop the transistor ?
  11. wayneh
    Sep 9, 2010
    12,379
    3,232
    What transistor? The TL431 has one inside it that should be adequate for switching your relay.
  12. renemonte
    Oct 7, 2016
    13
    or an op amp with a zener diode as a reference voltage
  13. FroceMaster
    Jan 28, 2012
    402
    Something like this, ?
    Will it work, ? use lamp as relay....
    Have calulatet 10k and 2k4 gives a 12,916 v, and that is fine,
  14. wayneh
    Sep 9, 2010
    12,379
    3,232
    I don't believe you need R3 in parallel with the relay although I'm not certain. It is in the example circuits to prevent the LED from glowing dimly while the TL431 is "off". That's not relevant to your relay. Again, I'm not 100% certain and anyway it wouldn't waste much current.
    But you should add a reversed-biased diode there. It will not conduct in normal operation, but will allow the magnetic field in the relay to collapse when it is switched off. This will protect the TL431 from a potentially high voltage spike. Something like 1N4007 or any other silicon diode rated to at least 2X the relay voltage and same or more current. Very cheap insurance.
  15. FroceMaster
    Jan 28, 2012
    402
    So something like this will deffintly do the job, as i understand the TL431
      File size:
      14.5 KB
      12
    wayneh likes this.
  16. AnalogKid
    Aug 1, 2013
    4,686
    1,297
    Zener diode(s) in series with the base.
    ak
  17. #12
    Nov 30, 2010
    16,670
    7,314
    That should work.
  18. ronv
    Nov 12, 2008
    3,393
    1,454
    Does the relay draw 100 ma?
  19. FroceMaster
    Jan 28, 2012
    402
    It only draws 12v/ 390 ohm coil = 30 mA
