Star/delta connections little help
Discussion in 'General Electronics Chat' started by Coefficient, Jul 10, 2016.
  1. Coefficient
    Sep 5, 2012
    37
    Like i always come here for guidance and other things when i am stucked on some confusions
    Lately,i am reading up star/delta transformations and there are few things i really want to understand well.
    From what i understand so far******The delta-star resistor network can be equivalent to a network of star-delta resistors connection and vice versa through a process of delta-star or star-delta transformation. As such, the electrical performance of the interchangeable delta/star or star-delta resistors networks will be identical*********.
    Now,in the attached file lies my questions;
    1... in fig 2.......If one of the resistors in a series circuit is shorted, what would happen to the supply current?
    2.... in fig 2....If one of the resistors in a parallel circuit is disconnected, what would happen to the supply current?
    3... For the circuit in Figure 1, if both E1 and Vab were doubled, what happened to the currents I1, I2 and Iab
    4... why the resistors connected in delta can be replaced by the resistors connected in star and vice versa..
    few of these questions i have for now,hope to have a good understanding from all responses.
    Regards
  2. wayneh
    Sep 9, 2010
    12,382
    3,240
    Forget the numbers, what do you think would happen qualitatively? Could the supply current ever go down as a result of shorting a resistor?
    Likewise, what do you think would happen qualitatively? Could the supply current ever go up as a result of removing a resistor?
    In both cases, the answer comes from Ohm's law. If there was a voltage drop to begin with, changing the resistance up or down will change the current. If there was no voltage drop, then a change will make no difference.
    Eventually you need a quantitative answer, and I think if you work out the math to answer your own questions, you'll come to have a much better feel for it.
  3. shteii01
    Feb 19, 2010
    3,500
    511
    Smells like homework.
    Rodney Phillips likes this.
  4. rbtmcm
    Jun 18, 2016
    A star connection can be replaced by an equivalent delta connection, and vice versa. See attachment.
    A more intuitive solution would be to apply Thevenins theorem to the circuit shown by you.
  5. WBahn
    Mar 31, 2012
    18,087
    4,917
  6. MaxHeadRoom
    Jul 18, 2013
    10,839
    2,516
    If you are looking for information on star delta configuration wave forms etc, I would have though a Google for 3ph Transformer modes of operation would have given you more useful information?
    Max.
  7. WBahn
    Mar 31, 2012
    18,087
    4,917
    Why do you think that? I don't see anything in the question that even hints at this being related to transformers, let alone three phase AC circuits. Both of his circuits are DC resistive circuits.
    Of his four questions, the first three don't seem to need ANY reference to delta or wye connected circuits to answer. As for the fourth, that is directly addressed by the link I recommended.
  8. Coefficient
    Sep 5, 2012
    37
    This is not a homework.
    just trying to learn things........i hope to be like you someday to help others
  9. Coefficient
    Sep 5, 2012
    37
  10. WBahn
    Mar 31, 2012
    18,087
    4,917
    Even if it's not official homework, it's still homeworkish in that you are trying to learn things instead of just trying to solve a specific problem, so the same approaches mostly apply, namely that you need to do most of the work and a lot of the struggling and have others just provide hints, clues, leading questions, and so on to help keep your struggle moving forward.
