Star and delta connections for motors
Discussion in 'General Electronics Chat' started by jiugo.llamas, Nov 23, 2007.
  1. jiugo.llamas
    Nov 23, 2007
    10
    Hi everyone, I have a motor which could be either connected in delta or star, this motor will be used for moving a conveyor band, which are the differences between delta and star connection for this purpouse? which one is the best connection?
  2. GS3
    Sep 21, 2007
    408
    35
    Foir all porpoises your best bet is to look at the plate on the motor which should tell you the voltage and other characteristics.
  3. jiugo.llamas
    Nov 23, 2007
    10
    Hi, the motor´s plate show me both choices, but it doesn´t give me any information related with the connection. Moreover, because it is a dual voltage it shows 2 connectios (delta and star) in low voltage and other two in high voltage...
    The plate shows:
    Star connection (230V) - Low start
    Delta conecction (230V)- Low run
    Star connection (460V) - High start
    Delta conecction (460V)- High run
  4. GS3
    Sep 21, 2007
    408
    35
  5. jiugo.llamas
    Nov 23, 2007
    10
    Thank you so much, I think this will help me...
    Regards
