Hey guys searched for other threads on specific subject so started this one. I own a Generac 24/7 20kw LP fueled generator wired into the house 200amp panel professionally. Provides 2 legs of 60hz thereby servicing the entire panel and runs perfectly, due to proper servicing and always being provided natural gas. We are considering selling the house and I want to take it with me but leave the ''fixture'' switch attached to house. The service tech factory guy says ''unit won't operate without switch'' but I think factory tells him to say that for safety and future business. It does not make sense to me. We had to buy switch separately and although it is fancy with thinkers and checkers, fuses and contactors verifying that line voltage is not present before disconnecting automatically from grid and starting generator. Takes 20 seconds. I do understand the safety aspect of this; one MUST verify and isolate line voltage from the house before starting generator. The generator exercises for 30 minutes 1x per week, so it will run while line voltage is present, which tells me it would run if not connected to anything/ house or grid. Because switch is open disconnecting generator from line and house. I can start manually and verify with meter both 60hz legs, they are just not being allowed to go past terminal on generator. Therefore, if I take generator to location B, to use as a manually operated generator through designated circuits; understanding all safety conditions required; this unit should work or not be prevented from working by some pre engineered electrical safety crap designed into circuit board on generator. It looks fancy also with small communication wires that I believe communicate with switch on line voltage protocols. This is my concern. WILL IT WORK IF DISCONNECTED FROM SWITCH OR will it only work disconnected from switch if I do X,Yand Z with these communication wires to tell circuit board at generator it's OK to start.
I have owners manuals schematics and can take pictures of anything needed to SAFELY figure this out or determine it's not good idea. Skill set is; I can safely handle the 2 power legs without killing myself or line worker, but these proving circuits and protocols, schematics....I got NOTHIN.
Thanks in advance for real world advice, safety precautions, do's and don'ts, and furthering my knowledge of these circuits as this community already has just from reading and researching other interesting subjects.
Generac model #0047231 Type code: SG020-A161.5N36PDYYC single phase 20 kw AMPS 166.7/83.8
