Standardization of audio magnitude
SPQR
Joined Nov 4, 2011
379
Howdy,
General question about audio data.
I have many many CDs and DVDs, and the vast majority of the sound fine when you play them through the audio/video system.
A few of them are problematic in that their "volume" or "magnitude of the audio" is so low that I have to crank up the volume significantly to hear them at the usual level for my ears.
My question is if there is a "standard" way of recording data on a CD/DVD such that the "average" magnitude of all the audio is similar for all audio data?
Another way of asking - Is there an audio standard which says something like "before recording an audio track on a DVD or CD, you must adjust the mean volume/magnitude will be X."
I thank you in advance
Veracohr
Joined Jan 3, 2011
772
No, there's no standard. In general for professionally-produced popular music, these days the average level is much higher than in the past. They call it "the loudness wars", and it's generally regarded as a bad thing, because it got out of hand and sucked the interesting dynamics out of music.
I'd say the problem is not necessarily your 'quite' CD's, but the loud ones.
By the way, this is all done in the mixing and mastering, before the data actually gets written to the CD. It's done with dynamic range processors like compressors and limiters.
thatoneguy
Joined Feb 19, 2009
6,359
One option is to make a media center.
Essentially, rip all of your CDs to high bitrate/high resolution MP3s, with "Volume Normalization" enabled.
You could then play the MP3s through a PC interface.
Another, messy option would be to rip all of the CDs to .wav format (no quality loss as you get with lower sampled .mp3), with Volume Normalization enabled, then write the songs back to a CD-R to play in your home system.
Volume Normalization is but one of hundreds of options that can be applied when ripping/encoding CDs, equalization, dynamic range expansion/compression, hiss suppression (for old (80's era) AAD CDs), and more.
Many producers will emphasize or de-emphasize bass based on the flavor of music, record at a lower average level for wide dynamic range for classical, etc. These enhancements can be undone very well with modern DSP on fast systems.
SPQR
Joined Nov 4, 2011
379
Ok, very interesting.
The one thing in electronics that isn't standardized!!!!:)
I was just thinking about it while driving in my car at lunch.
I have 30-40 CDs uploaded to my car DVD player, and all of them sound "pretty close" except for one CD (Muti's "I Pini di Roma") where I have to really crank up the volume.
Then I switch back to Led Zeppelin - and my eardrums are toast!:D
Thanks again!
thatoneguy
Joined Feb 19, 2009
6,359
My copy of Audio Cyclopedia, section 10.8, page 447, says 1 mW into 600Ω which works out to 0.773 volts.
(Tremaine, Howard M. (1973). Audio Cyclopedia. Howard W. Sams & Co..}
Also see
http://en.wikipedia.org/wiki/DBm
That is the science specification for recommended standard.
"Artists" think science is icky, you can get two CDs of an orchestra playing the same sheet music, from different producers, and they usually sound vastly different.
SPQR
Joined Nov 4, 2011
379
This corresponds to the 0dBm level on a VU meter.
(Tremaine, Howard M. (1973). Audio Cyclopedia. Howard W. Sams & Co..)
Also see
Aha! That's the type of "rule" I was looking for!!
But as stated in Ghostbusters..."it's more of a guideline than a rule":D
Papabravo
Joined Feb 24, 2006
21,228
It wasn't Ghostbusters -- it was the pirate sidekicks with the goofy eyeballs in "Pirates of the Caribbean" -- Eh poppet!
