Standard Electric Time clock
Discussion in 'The Projects Forum' started by obmcclintock, Jan 21, 2013.
  1. obmcclintock
    Jan 21, 2013
    I have two Standard Electric Time clocks that need to be operated by some sort of a master clock. I hope I have used the right terminology. I do not need a master clock if i could obtain some kind of pulsing machine that could give a low voltage current surge every minute. Do they make something kinda simple that does such a thing as I am not that electronics savvy. Thank you for your responses! Dave
  2. wayneh
    Sep 9, 2010
    12,388
    3,244
    I can't speak for anyone else, but I have no idea what you're talking about. :p
    tshuck likes this.
  3. BillB3857
    Feb 28, 2009
    2,402
    348
    absf likes this.
  4. thatoneguy
    Feb 19, 2009
    6,357
    718
    Are these from a school surplus or similar? So all of the clocks in a building show the same time, or are they time reference circuits that provide 1 second pulses?
  5. atferrari
    Jan 6, 2004
    2,666
    784
    Used in ships.
    Able to set the time back or advance it while crossing the time zones while underway.
    They are commanded by the master clock which is in the bridge.
  6. wayneh
    Sep 9, 2010
    12,388
    3,244
    So the OP - if he's still around - needs a clock pulse to act as the master, to synchronize these two slave clocks? I'm assuming these would need to be accurately timed (ie. not a 555 timer solution) and therefore he probably needs a quartz crystal oscillator and digital circuit to deliver a synch signal.
  7. THE_RB
    Feb 11, 2008
    5,435
    1,305
    There's a clock guy on the electrotech-online (ETO) forum that has a lot of standard electric clocks and specialist clock circuits.
    I know it's rude to advise someone to go to another forum but that might be a better place to ask. :)
