Stand Alone Arduino
Discussion in 'Programmer's Corner' started by kurtruk, Jun 7, 2014.
  1. kurtruk
    Aug 26, 2012
    140
    6
    I am working on a project that will eventually use a stand alone arduino. It needs to communicate to the PC via USB. Do I need a seperate chip to handle these communications or can I just connect the USB data pins to pins 0 and 1 on the atmega?
    Note: I can easily program it with the arduino uno that is not a issue. But the program needs USB input and output to run.
  2. sirch2
    Jan 21, 2013
    1,008
    351
    You cannot connect the TX/RX on the arduino to USB directly but there are "USB to Serial" adapters available cheaply on ebay etc. You then connect TX/RX to the adapter and then connect that to the USB on your PC.
    I think it is typically better to use one of these than to put an FTDI chip on your standalone board since it will consume power and add complexity that you don't need.
    <edit>
    Of course what I meant to write was:
    You cannot connect the TX/RX on the ATMega to USB directly
  3. shteii01
    Feb 19, 2010
    3,500
    511
    I worked with Arduino Due board, it has USB. I simply plugged Due to pc using USB cable (follow driver installation instructions), it worked fine and I had no trouble sending data from Due to pc.
    UNO has USB already.
    From UNO website:
    http://arduino.cc/en/Main/ArduinoBoardUno
    "An ATmega16U2 on the board channels this serial communication over USB and appears as a virtual com port to software on the computer."
    "The Arduino software includes a serial monitor which allows simple textual data to be sent to and from the Arduino board."
    djsfantasi likes this.
  4. kurtruk
    Aug 26, 2012
    140
    6
  5. djsfantasi
    Apr 11, 2010
    2,899
    870
  6. kurtruk
    Aug 26, 2012
    140
    6
    Yes I did. In my original question and title it says stand alone arduino so that means just the atmega chip not the whole arduino uno. Why pay for a whole new uno when you can get an atmega chip for a couple bucks.
  7. djsfantasi
    Apr 11, 2010
    2,899
    870
    Ahh. Terminology confusion. To me, Arduino is a system and an Atmega is a microcontroller. Hence, I personally think that a standalone Arduino doesn't exist. I'd use "Atmega" instead. To each his own.
  8. shteii01
    Feb 19, 2010
    3,500
    511
    Ok, so you are just going to use ATmega328 chip.
  9. sirch2
    Jan 21, 2013
    1,008
    351
  10. shteii01
    Feb 19, 2010
    3,500
    511
    I saw a tutorial about stand alone ATMega328, they said if you use cable, then you need a couple transistors and resistors to interface the cable to the ATMega328.
    This one here: http://www.hobbytronics.co.uk/arduino-atmega328-hardcore
    They explain how to use the little board you linked and how to use USB to serial cable.
  11. kurtruk
    Aug 26, 2012
    140
    6
    Alright. Thanks!
  12. GetDeviceInfo
    Jun 7, 2009
    1,571
    230
