I understand your reasons for discrediting many of these claims. And you are right
And wrong in your conclusion. Before I say any more about wfcs. Let's look at this
From another point shall we?
Modern electon theory as taught forbids the sending of electrical power down a single
Wire in an open system. Yet many modern day electric companies are now building
The infrastructure to do precisely this. Its called SWER. Several countries are now doing
This and so is the USA in some areas. This is essentially, the Avramenko pump! Did you
Ever build this ckt? I did and it works! This system will send voltage only down a single
Wire many times smaller than our current cables, while also getting ridof the ground and
Return wires. Google it! A huge costs savings for the power company. Not too mention
Not requiring all the boosting relay stations.
Recently, konstantin meyl has experimentally shown along with many other universities
That power can be sent wirelessly as well. Aka Tesla's wireless power system. Debunked
And ridiculed for a century! I built this ckt as well and the output exceeds the input power.
It does this from scavaging electrons near the other terminal an the space between them.
Also already proven numerous times. Besides, doing yourself is always the best way to
Verify a claim.
If you think there's no such thing as overunity systems, then you might wonder how your
Airconditioner works so well? This is an undisputed overunity system in any physics text
Book. Read about it. Physics already recognizes this to exceed the input. But its an open
System you see. That's the key!
In fact, the laws only pertain to closed systems in equilibrium and not apply to open systems.
This is in any modern physics textbook! The 2nd law of thermodynamics only applies to closed
Systems in equilibrium period! Right in your textbook!
As far as electrical overunity goes. Imagine it this way. You have a measly battery. Connected
Thru an open system to another resonant ckt. Now you have access to many separate sources
If you will and not just your feeble battery. Would not then the output appear to put out more
Than what your tiny battery can produce? Of course. But the total power comes from other sources
Together with your source. It would appear to defy the laws would it not?
Being open and resonant means it can couple with anything around it or linked to it ontop of
What you input into the network. Its as if you have an unlimited supply coupled to your ckt if
Designed right. The problem with overunity is the simple observation of more out than input.
Ppl can't wrap their heads around the fact that once the ckt is open. Your total power is no
Longer just your main pwr source. But in fact mutiple sources.
Verify a claim.
