Basically our objective is to get the stampbug to do 'gymnastics'.
We will be awarded marks for musical interpretation, entertainment factor, technical content, visual/audio/special effects, mechanical aids and floor coverage.
I have attached an image of the stampbug to the post, also here is a link a previous team had done
http://www.youtube.com/watch?v=dpkEgp5QdZM
We have a £50 budget, and we kind of need a 360 degree servo ( I can't give too many details away as to what we are planning as we are in competition with other groups) and these could eat at our budget so we were thinking of trying to modify a 180 servo to rotate 360 degrees, has anyone experience doing this, if so how did you do it?
Also does anyone have any suggestions on mounting the servo, as if we are to have a 360 servo, we could run run into problems with wiring. We were thinking of just having the servo rotate 180 degrees then back 180 degrees if we can't find a way over this problem.
Many Thanks.
Many Thanks.
