Stainless Steel Threads -- locking and galling?
Discussion in 'General Science' started by cmartinez, Jan 14, 2016.
  1. cmartinez
    Thread Starter AAC Fanatic!
    Jan 17, 2007
    3,698
    2,789
    MOD NOTE: This is an off-shoot of another unrelated thread and is being split off in case anyone would like to discuss it further.
    Sometimes, the last thing you want is for threads to lock... especially when dealing with stainless steel fittings:
    shortbus likes this.
  2. #12
    Nov 30, 2010
    16,703
    7,341
    I use that on my soldering iron tips after I got tired of unscrewing the heater element by accident.:eek::D
    cmartinez likes this.
  3. #12
    Nov 30, 2010
    16,703
    7,341
    That sounds like something a mechanical design engineer would never think of or design into a product. I suppose some of them know about this, but if I ever saw it in the real world, I didn't know what I was looking at. Is this common practice? Is it just one of those things one picks up over the years, and most people don't know?
  4. JohnInTX
    Jun 26, 2012
    2,394
    1,051
    OT maybe but @GopherT has a point, according to Fastenal. If you want to continue in a new thread let us know.
    #12 likes this.
  5. #12
    Nov 30, 2010
    16,703
    7,341
    We already finished the conversation in PM.
    JohnInTX likes this.
  6. WBahn
    Mar 31, 2012
    18,087
    4,917
    My guess is that the galling of stainless steel is a topic that few people know much about unless they have had need to work with stainless steel, in particular threads, in a situation in which galling was an issue. Then, whether engineers, technicians, or mechanics, they learn about the issue and the common tricks to deal with it.
  7. cmartinez
    Jan 17, 2007
    3,698
    2,789
    Mhhh.... I kind of like it that it was moved to the General Science forum instead of simly Off Topic
  8. cmartinez
    Jan 17, 2007
    3,698
    2,789
    What I'd like to know is the why of this phenomenon... is it a chemical thing? or does it have to do with the alloy structure or some other physical forces?
  9. #12
    Nov 30, 2010
    16,703
    7,341
    Well, if you're going to cut me some new territory to work with, I will post the pdf which Gopher provided in the PM session.
    WBahn likes this.
  10. WBahn
    Mar 31, 2012
    18,087
    4,917
    Different materials have different wear characteristics due to different surface physics. A lot of factors come into play. Aluminum is notorious for galling, as are most allows of stainless steel. If you have extremely clean steel (don't know how sensitive to alloy composition it is) plates in contact with much pressure at all and try to slide them they will cold weld to each other.
    Surface physics is, in general, an extremely complicated field that we are always learning new things about and that many of the things we have learned how to exploit we don't really know what the true underlying phenomena are.
  11. wayneh
    Sep 9, 2010
    12,388
    3,245
  12. cmartinez
    Jan 17, 2007
    3,698
    2,789
    That should make it an extremely interesting subject for any materials engineer looking for an appropriate theme for his thesis and disertation.
  13. WBahn
    Mar 31, 2012
    18,087
    4,917
    It is a VERY active field of research in many disciplines. Physics, Metallurgy, Materials Science, just to name a few. Papers are constantly being published and there are numerous opportunities for students at all levels (undergraduate to post-doctoral) to be involved.
  14. #12
    Nov 30, 2010
    16,703
    7,341
    I ran across a TV show about 3 this morning that focused on the idea that surfaces are where chemical interactions take place, like, life didn't arrange itself in a soup, it arranged itself on a surface.
    ps, I have no intention of proving that TV show was correct or that God said, "Let there be surfaces". It was just a TV show with an interesting perspective.
  15. cmartinez
    Jan 17, 2007
    3,698
    2,789
    It does make sense.... after all, every physical contact between 3D bodies occurs in either 1 or 2 dimensional surfaces.
  16. #12
    Nov 30, 2010
    16,703
    7,341
    It's counter-intuitive to me. All 3D bodies can bump into other 3D bodies, and there is more movement in a soup because surfaces in a fluid tend to have a stagnant layer on their surface. Just saying, if it's true, it's news to me. Like, molecules bump into each other and bind together better if they are holding still? I have doubts.
    GopherT likes this.
  17. wayneh
    Sep 9, 2010
    12,388
    3,245
    Molecules yes, but living things all have membranes that define self from non-self. Inside from outside. A lot goes on at that interface, especially in us mammals. Our membranes have ion channels, molecule receptors, all sorts of things.
    Still, I'm not sure it's all that useful to focus on surfaces. Anything involving DNA replication, for instance, takes place in soup.
    #12 likes this.
  18. joeyd999
    Jun 6, 2011
    2,757
    2,932
    I've always considered it fascinating that life tends to occur "on the margins" (macro view). For example, at the interface between land and air, land and water, and water and air.
  19. nsaspook
    Aug 27, 2009
    3,013
    2,367
    The surface is where the greatest energy kink usually exists. Where things are kinky is usually where the fun begins.;)
  20. joeyd999
    Jun 6, 2011
    2,757
    2,932
    Interesting you bring up energy.
    Another of my fascinations is that life only exists at very low energies -- equivalent to temperatures between, roughly, 273K to 325K in a universe where temperatures span from close to 0K to millions of K.
    In fact, in my estimation, most matter in the universe exists either very close to 0K or at temperatures much greater than 10,000K. This makes it surprising that life happens in such a narrow band.
    Of course, this can be explained away by the antrhopic principle: life exists in such a narrow range only because we exist here in that range to ask the question.
    More substantially, the binding energies of the organic molecules that support life are so small that they could not organize to support life at higher temperatures. Even more so are the all important weak hydrogen bonds that mediate the interactions between, and govern the processes performed by, such organic molecules.
    Still, you'd think the universe would come up with another class of "organic" molecules that could organize at the higher temperatures and energies at which most matter in the universe exists.
    Sorry for pulling this thread so far off topic!
