'Stacking' power supplies?
Discussion in 'General Electronics Chat' started by Nicholas, Feb 2, 2013.
  1. Nicholas
    Thread Starter AAC Fanatic!
    Mar 24, 2005
    121
    Hey guys!
    Just a general question. If I have two 36V 10A switched mode power
    supplies, can I 'stack' them to get 36V 20A ?
    Thanks!
  2. KMoffett
    Dec 19, 2007
    2,584
    234
    ??????...No!
    Ken
  3. ErnieM
    Apr 24, 2011
    7,442
    1,628
    Generally what happens is one supply has a slightly higher output voltage, so that one runs in current limit mode (may be noisy) with the other supply delivering the lesser current.
    They do not share equally... if you take out less then 10 amps most all comes from that one supply.
    It may work, it may not. It's a coin flip without knowing the specific supplies involved.
    SPQR and PackratKing like this.
  4. Papabravo
    Feb 24, 2006
    10,340
    1,850
    #12 likes this.
  5. bountyhunter
    Sep 7, 2009
    2,498
    507
    Depends on the supply. Some have rear panel connectors so the PS can be used as a current source. If you aren't sure, don't do it. You'll blow it up.
