Stacked patch antenna design
Discussion in 'Wireless & RF Design' started by Priyatharshini, Feb 2, 2012.
  1. Priyatharshini
    Feb 1, 2012
    Hi..
    I want to design stacked patch antenna by this spec...
    Parameter---------Min------------Max-------- Description
    arU------0.6------ 1.4------ Aspect ratio for the upper patch
    xU-------20mm----68mm--- The x-dimension for the upper patch
    arL------ 0.6------ 1.4------ Aspect ratio for the lower patch
    xL------- 20mm----68mm--- The x-dimension for the lower patch
    tL------- 0.1mm---10mm----Thickness of the lower dielectric layer
    tU-------0.1mm---10mm--- Thickness of the upper dielectric layer
    εU-------1.0------7.0------ Relative permittivity of the upper dielectric layer (μ_r=1.0)
    εL------- 1.0------ 7.0------ Relative permittivity of the lower dielectric layer (μ_r=1.0)
    xfeed----0.2mm---10mm----Distance of feed probe from the edge of patch
    These are my spec.. want to design stacked patch antenna... plz help me... I am having MATLAB software... If u know the coding plz post here or send to my mail <SNIP>...
    Thanks.........
  2. radiohead
    May 28, 2009
    474
    31
    what's the application for the stacked antenna?
