using pic18f4520 and mplab c18 compiler for the below program
1) the program stops working within a minute(stack overflow?)
2) the first character of last line in 20x4 lcd keeps blinking
3) code works in 16x2 lcd but on a 20x4 lcd displays output of its choice and cannot be controlled
initialization of lcd and adc is fine
pls help me out,point out the error
Rich (BB code):
#include <p18f4520.h>
#include <adc.h>
#include <stdlib.h>
#include <delays.h>
#include <stdio.h>
#define lcdport LATB
#define E LATDbits.LATD7
#define RS LATDbits.LATD6
#define p_bar PORTAbits.RA1
#define wh_l PORTCbits.RC0
#define wh_ul PORTCbits.RC1
#define sph_l PORTCbits.RC2
#define sph_ul PORTCbits.RC3
#define sp_on PORTDbits.RD0
#define sp_off PORTDbits.RD1
#define _XTAL_FREQ 20000000
#pragma config WDT=OFF,LVP=OFF,STVREN=OFF,MCLRE=OFF
unsigned int adc_out=0;
int reg1,reg2,reg3;
float adc_rpm;
unsigned char convolt[5];
unsigned char anim[8]={0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00};
unsigned char anim0[8]={0x19,0x19,0x19,0x19,0x19,0x19,0x19,0x19};
unsigned char anim1[8]={0x0E,0x0E,0x0E,0x0E,0x0E,0x0E,0x0E,0x0E};
unsigned char anim2[8]={0x0F,0x0F,0x0F,0x0F,0x0F,0x0F,0x0F,0x0F};
unsigned char anim3[8]={0x1F,0x1F,0x1F,0x1F,0x1F,0x1F,0x1F,0x1F};
unsigned char anim4[8]={0x13,0x13,0x13,0x13,0x13,0x13,0x13,0x13};
void lcdbuild(unsigned char,unsigned char *);
void lcdmsg(const rom char *);
void lcdstr(unsigned char *);
void lcdcomm(unsigned char);
void lcddata(unsigned char);
void lcdout(unsigned char);
void dispchar(void);
void animate(void);
void animate1(void);
void animate2(void);
void animate3(void);
void animate4(void);
void lcdinit(void);
void clear(void);
void blank(void);
void blink(void);
void blink_1(void);
void blink_2(void);
void blink_3(void);
void loop(void);
void ucall(void);
void pcall(void);
void scall(void);
void adc(void);
void pressure(void);
void workhead(void);
void sphere(void);
void spindle(void);
void main (void)
TRISA = 0x0F;
TRISB = 0x00;
TRISC = 0xFF;
TRISD = 0x0F;
lcdinit();
dispchar();
animate();
lcdcomm(0x86);
lcdmsg("MAXPRECI");
animate1();
animate2();
animate3();
animate4();
animate3();
animate2();
animate1();
animate();
Delay10KTCYx(1000);
Delay10KTCYx(1000);
lcdcomm(0xCD);
lcdmsg("RPM:");
lcdcomm(0x94);
lcdmsg("WH:");
lcdcomm(0x9E);
lcdmsg("SPH:");
OpenADC(ADC_FOSC_32 &
ADC_RIGHT_JUST &
ADC_4_TAD,ADC_CH0 &
ADC_INT_OFF &
ADC_VREFPLUS_VDD &
ADC_VREFMINUS_VSS, 7);
while(1)
loop();
CloseADC();
void loop(void)
adc();
// pressure();
if(wh_l==1 | wh_ul==1)
workhead();
else if(sph_l==1 | sph_ul==1)
sphere();
else if(sp_on==1 | sp_off==1)
spindle();
void pressure(void)
if(p_bar==1)
reg3=0;
clear();
lcdcomm(0xC0);
lcdmsg("Pressure OK");
if(p_bar==0)
reg3=1;
blank();
lcdcomm(0xD4);
lcdmsg("Pressure Below 6BAR");
pcall();
void workhead(void)
if(wh_l==1)
reg1=0;
lcdcomm(0x97);
lcdmsg("Lock");
if(wh_ul==1)
reg1=1;
ucall();
void sphere(void)
if(sph_l==1)
reg2=0;
lcdcomm(0xA2);
lcdmsg("Lock");
if(sph_ul==1)
reg2=1;
ucall();
void spindle(void)
if(sp_on==1)
scall();
if(sp_off==1)
blank();
lcdcomm(0xD4);
lcdmsg("Spindle:OFF");
void ucall(void)
while(reg1==1 & reg2!=1)
lcdcomm(0x97);
lcdmsg("UnLock");
blink_1();
loop();
while(reg2==1 & reg1!=1)
lcdcomm(0xA2);
lcdmsg("UnLock");
blink_2();
loop();
while(reg1==1 & reg2==1)
lcdcomm(0x97);
lcdmsg("UnLock");
lcdcomm(0xA2);
lcdmsg("UnLock");
blink_3();
loop();
void pcall(void)
while(reg3==1)
lcdcomm(0xC0);
lcdmsg("Low Pressure");
blink();
pressure();
void scall(void)
if(reg1==0 & reg2==0)
blank();
lcdcomm(0xD4);
lcdmsg("Spindle:ON");
if(reg1==1 | reg2==1)
blank();
lcdcomm(0xD4);
lcdmsg("Error WH/SPH UnLock");
void adc(void)
SetChanADC (ADC_CH0);
Delay10KTCYx(10);
lcdcomm(0xD1);
lcdmsg(" ");
ConvertADC();
while(BusyADC());
adc_out=ReadADC();
adc_rpm=(adc_out*500.0)/1024;
itoa(adc_rpm,convolt);
lcdcomm(0xD1);
lcdstr(convolt);
Delay10KTCYx(1000);
void dispchar(void)
lcdbuild(0,anim);
lcdbuild(1,anim1);
lcdbuild(2,anim2);
lcdbuild(3,anim3);
lcdbuild(4,anim4);
lcdbuild(5,anim0);
void lcdbuild(unsigned char location, unsigned char *ptr)
unsigned char i;
if(location<8)
lcdcomm(0x40+(location*8));
for(i=0;i<8;i++)
lcddata(ptr);
void lcdmsg(const rom char *Message)
const rom char *Pos = Message;
while(*Pos!=0)
lcddata(*Pos++);
void lcdstr(unsigned char *str)
int i=0;
while(str!='\0')
lcddata(str);
i++;
void lcdcomm(unsigned char i)
RS =0;
lcdout(i);
Delay1KTCYx(2);
void lcddata(unsigned char i)
RS =1;
lcdout(i);
Delay1KTCYx(2);
void lcdout(unsigned char dat)
lcdport = dat;
E = 1;
Delay1TCY();
E = 0;
void lcdinit(void)
lcdport=0x00;
Delay1KTCYx(40);
lcdout(0x30);
Delay1KTCYx(15);
lcdout(0x20);
Delay1KTCYx(15);
lcdcomm(0x38);
lcdcomm(0x0C);
lcdcomm(0x01);
lcdcomm(0x06);
lcdcomm(0x80);
void blank(void)
lcdcomm(0xD4);
lcdmsg(" ");
void clear(void)
lcdcomm(0xC0);
lcdmsg(" ");
void blink(void)
Delay10KTCYx(200);
lcdcomm(0xC0);
lcdmsg(" ");
Delay10KTCYx(100);
void blink_1(void)
Delay10KTCYx(200);
lcdcomm(0x97);
lcdmsg(" ");
Delay10KTCYx(100);
void blink_2(void)
Delay10KTCYx(200);
lcdcomm(0xA8);
lcdmsg(" ");
Delay10KTCYx(100);
void blink_3(void)
Delay10KTCYx(200);
lcdcomm(0x97);
lcdmsg(" ");
lcdcomm(0xA8);
lcdmsg(" ");
Delay10KTCYx(100);
void animate(void)
lcdcomm(0x80);
lcdmsg(" ");
lcdcomm(0x82);
lcddata(3);
lcdcomm(0x83);
lcddata(2);
lcdcomm(0x84);
lcddata(1);
lcdcomm(0x85);
lcddata(5);
lcdcomm(0x8E);
lcddata(4);
lcdcomm(0x8F);
lcddata(1);
lcdcomm(0x90);
lcddata(2);
lcdcomm(0x91);
lcddata(3);
lcdcomm(0x92);
lcdmsg(" ");
Delay10KTCYx(100);
void animate1(void)
lcdcomm(0x80);
lcdmsg(" ");
lcdcomm(0x83);
lcddata(2);
lcdcomm(0x84);
lcddata(1);
lcdcomm(0x85);
lcddata(5);
lcdcomm(0x8E);
lcddata(4);
lcdcomm(0x8F);
lcddata(1);
lcdcomm(0x90);
lcddata(2);
lcdcomm(0x91);
lcdmsg(" ");
Delay10KTCYx(100);
void animate2(void)
lcdcomm(0x80);
lcdmsg(" ");
lcdcomm(0x84);
lcddata(1);
lcdcomm(0x85);
lcddata(5);
lcdcomm(0x8E);
lcddata(4);
lcdcomm(0x8F);
lcddata(1);
lcdcomm(0x90);
lcdmsg(" ");
Delay10KTCYx(100);
void animate3(void)
lcdcomm(0x80);
lcdmsg(" ");
lcdcomm(0x85);
lcddata(5);
lcdcomm(0x8E);
lcddata(4);
lcdcomm(0x8F);
lcdmsg(" ");
Delay10KTCYx(100);
void animate4(void)
lcdcomm(0x80);
lcdmsg(" ");
lcdcomm(0x8E);
lcdmsg(" ");
Delay10KTCYx(100);
