Stabimatic AVR stablizer did not provide proper voltage, its excess voltage lamp continously at the on position (you can see it through image) however the input voltage is quiet normal. The gear box and the mini motor running fine and move freely at startup but after that it stuck at the end point. Due to this my system has been restarted several times.
Any suggestion!
Here it is stuck the excess voltage button always on.
Any suggestion!
