Stabilize problem properties in controlsystem
Discussion in 'Homework Help' started by Chrill3, Oct 12, 2011.
  1. Chrill3
    Mar 8, 2010
    9
    I have a characteristic equation that yields
    s^3+as^2+s+b=0
    I am supposed to determine the areas in ab-plane that correspond to a stabile system, I just dont know how to begin with, is it Ruth Hurwitz Iam supposed to use?, any hint is welcome:)
  2. t_n_k
    Mar 6, 2009
    5,448
    783
    You can certainly use Routh-Hurwitz criterion. Presumably you are considering a linear time-invariant system.
    For your case
    s^3+as^2+s+b=0
    Two conditions must be met
    1. the coefficients of all terms on the LHS of the equation must be greater than zero. So in particular a and b must be greater than zero.
    2. a>b
