stability of a trimpot
Discussion in 'General Electronics Chat' started by bug13, Jun 6, 2013.
  1. bug13
    Feb 13, 2012
    1,214
    38
    Hi
    Can I reply on the output of a regular trimpot to remain the same value over a range of temperature and time.
    My understanding is, it's just like a two-resistor voltage divider, but those two resistors are made of same material, so their temperature coefficient and aging should be at the same rate.
    Hence the ratio of those two resistors value will be the same over a range of temperature and time?
