st93c66 replacement
Discussion in 'General Electronics Chat' started by jody, Oct 6, 2013.
  1. jody
    Nov 12, 2012
    39
    i want to replace a duff st93c66 eeprom and have a m93c66. the difference is the st93 is clock speed 1MHz and the m93 its modern replacement is 2MHz. will it work on the 1MHz clock.
  2. MrChips
    Oct 2, 2009
    12,636
    3,455
    I don't see any reason why it shouldn't work. (I have not looked at the specific datasheets.)
    jody likes this.
  3. jody
    Nov 12, 2012
    39
    according to the spec sheets the only thing i can see is that the clock speed for the st is 1mhz and the m is 2 mhz. so im guessing that the m will run happily with a 1 mhz clock.or does it mean it has to be 1mhz???
  4. MrChips
    Oct 2, 2009
    12,636
    3,455
    You can operate a component at a lower speed.
    Running a component at a speed higher that its rated speed is not recommended.
