What does the datasheet for the relay recommend?Hi all,
I am going to use an Omron G3NA-240B solid state relay to switch a 1100W 240VAC device.
Is there a particular resistance value which I should use at the input therminal of the SSR?
Hi, I'm not sure about that. Is it the 15mA? so 5V/0.015 = 330ohms ?What does the datasheet for the relay recommend?
by Jake Hertz
by Jake Hertz
by Jake Hertz
by Jake Hertz
