SSOP 24 to DIP adapter with .635 pitch (.025")
Discussion in 'General Electronics Chat' started by PickyBiker, Dec 11, 2015.
  1. PickyBiker
    Aug 18, 2015
    56
    I am trying to find a SSOP 24 to DIP adapter with .635mm pitch (.025") Everything I have found so far is .65mm pitch. The chip I want to use is the Si4844 AM/FM/SW receiver. This chip doesn't quite line up on the .65mm adapters. People have said they were able to use a .65mm adapter for this ic but this is going to be my first SMT job. I would prefer to use an adapter that lines up perfectly to increase the odds of success.
    Does anyone have a source for that?
  2. sailorjoe
    Member
    Jun 4, 2013
    361
    63
  3. spinnaker
    Oct 29, 2009
    5,062
    1,159
  4. KeepItSimpleStupid
    Mar 4, 2014
    1,250
    218
  5. spinnaker
    Oct 29, 2009
    5,062
    1,159
  6. ErnieM
    Apr 24, 2011
    7,433
    1,623
    I second spinnaker's suggestion. That's what I use, and where I get them too.
    I keep a box of all different sizes on hand in advance of need. Same with proto boards, the "sea of holes" on 0.1" centers, plated thru on real FR4 material; I keep various sizes on hand.
    They take 2-3 weeks typically to make it to my door with the free shipping.
  7. spinnaker
    Oct 29, 2009
    5,062
    1,159
    I think the OP is worried about soldering that chip. I have done stuff just a little bigger but my hands are shaky and I got the job done. You should be able to do OK. Just read up on surface mount soldering.
  8. KeepItSimpleStupid
    Mar 4, 2014
    1,250
    218
    If proto-advantage has the part, you can get the stencil. Then it's cake.
  9. Veracohr
    Jan 3, 2011
    559
    77
  10. PickyBiker
    Aug 18, 2015
    56
